I am looking at the pulse and direction input lines on a EN-204 drive by Control Techniques / Emerson and have a question about driving them from the Kflop.
I think 24 user I/O lines from the Kflop are 5V tolerant. The EN-204 states that the pulse and direction pins if you use single ended are TTL level (the drive can also take differential pulse inputs as well as analog velocity/torque command voltages).
The actual statement is: TTL, 330 ohm pull-ups to internal 5 V, 1.5 V = low, 3.5 V = high
Since the Kflop is 5V tolerant on the 24 I/O lines, I am assuming the 330 ohm pull-up to 5V will be fine and will make a high level greater than 3.5V. What about sinking? Can the Kflop sink enough current to pull the line below 1.5V? That would be 3.5V/330 ohm = 10.6mA but for safety, something greater than 15mA would be comfortable. I could not find info on the webpage about how much current the 5V tolerant I/O lines can sink.
Thanks for any help
